Rear diff vent tube
gsparky
6.2 Diesel
It's a press in barb into the axle, 3/8 hose a band style clamp to hold the hose in place on the body directly above rear axle and then the little plastic vent valve.
My barb is broken off. Drilled it out to tap in for a 1/8” NPT brass nipple but the press in barb came out. Anyone know where these can be found?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Just tap the hole and put in a regular barb fitting and run a hose. That's what I did. Have to be careful about filings if the axle isn't disassembled.
GM says you can use a fuel filter oddly enough, 25055032
VENTING REAR AXLE ASSEMBLY​
1.Disconnect rear axle vent hose and vent at attachment to box floor cross sill or frame and axle housing. Typical attachments are shown in Figures No. 1A and 1B. Various other att achments are possible depending on axle size and model year.
2.Replace vent with filter, P/N 25055032, and secure to vent hose with a screw clamp, P/N 797923.
3.Install clamp on the body of the filter and install filter on the box floor (body floor) cross sill one rib REARWARD of the axle housing using the existing bolt. Filter outlet should face rearward. See Figures No. 2A and 2B.
4.Install 38 inches of 5/16 inch hose, P/N 9438315, on the filter securing with a screw damp.
5.Route the hose REARWARD to the left side frame rail and secure using plastic fasteners (ties). Let hose hang downward within left frame rail.
VENTING FRONT AXLE
1.Remove clamp holding the vent hose to the radiator support. See Figure No. 3A.
2.Remove the plastic vent from the hose and install filter, P/N 25055032, and secure with screw clamp.
3.Install six inches of 5/16 inch hose, P/N 9438315, on the filter with a screw clamp and relocate the filter to the canister attaching bracket. Let end of hose hang downward from filter. See Figure No.3B.
jw23655
