rear blinker...
jeremys14
texas
jeremy
Steering column. You'll need to remove the wheel and lock plate and there's your switch. The wiring threads down through the column.
How far are you from Austin? :rofl: I'm the resident wiring guru.
No. 10.
im about 5 hrs away. i was hoping
to not have to pull the wheel, being as ive never done it before
jeremys14
texas
jeremy
just looked at wiring from rear driver side across to passenger side under the bed. all i can say is wow. there's wires stripped here, spliced together there (without even electrical tape, i'm talking just twisted together) its a big clusterfkk under here.
towman
harrisburg pa
jay
v10
someone probably put a trailer light kit in there, the yellow wire is for the left side the green wire is for the right side, easy way to remember is yellow has the l in it for left and green has r for right
You problem is probably in that area then. I'd try to match up the wires, then use some shrink tube over the splices onces you have them all figured out. It can't be that. should be 4 wires and a ground at the most.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Yeah, tighten that up ASAP. I'd hate for your truck to burn up over a damned tail light
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
i've fixed numerous trucks with hard wired trailer connectors that did similar things. most of the problems have been under the truck, most of them involving the ground.
jeremys14
texas
jeremy
dug into loom under truck and 2 wires were cut. spliced back into lighting harness, and back to working.
Great !!! Thanks for the update. :waytogo:
jeremys14
texas
jeremy
no prob. she's inspected and tagged in my name, and possibly up for sale
Why sell it? Now that you got the blinker fluid filled, and its legal, just drive it.
jeremys14
texas
jeremy
wish i could my friends but it decided to have a rod start knocking today
Old used 350's are cheap. The last one I bought for $100 is in my broithers El Co. He says it runs great, and he has to add a quart about every 1200-1500 miles. He is changing the oil every 3000-4000, so about 2 quarts between changes.
rumph13
