rear blinker...
jeremys14
texas
jeremy
my pass rear blinker is not working. it lights up with the headlights, but doesn't come on with the blinker. all other turn signals work. any ideas? its on a 84 c20.
Have you checked the fluid in the rear blinker resevoir???
If the fluid level is OK, you might consider checking the ground strap the light. You'd likely have to pull the lenses out to check it. Its only 4 torx screws the get the lenses out. I'd pull it out for inspection. How about the brake light? Does it work OK on that same side?
towman
harrisburg pa
jay
v10
it is a double element bulb, half of it works the turn signal and brake light, the other element works the parking light
Yep, that's why I asked if the brake light is working. Part of problem elimination.
jeremys14
texas
jeremy
of course i checked the reservoir, i also checked they flux capacitor gasket. both were good. and no, the brake light isnt working either.
OK, so that narrows it down to that bulb, or that socket. Likely not the ground if the taillight is working.
jeremys14
texas
jeremy
changed bulb, and nothing. also cut off socket from spare truck i have and hardwired it into this truck (after cutting the other socket out) and nothing...
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
More than likely it's a bad connection at the turn signal switch...
jeremys14
texas
jeremy
would turn signal switch effect brake light aswell?
RetroC10Sport
Jay
pontiac aztek
Yes, it will. The brake light circuit goes through the turn signal switch.
jeremys14
texas
jeremy
where is signal switch located? i guess i'll have to find time next weekend to figure it out. the inspection is the only the remaining in making this thing legal!
RetroC10Sport
Jay
pontiac aztek
Steering column. You'll need to remove the wheel and lock plate and there's your switch. The wiring threads down through the column.
How far are you from Austin? :rofl: I'm the resident wiring guru.
No. 10.
:popcorn:
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
check your harness from the connecter to the tail lite
BigPapa
