really rusty door, helpp
86chevyk20
Buffalo
Liam
iv got a door i want to use to my k20, and its a china door but its solid. I bought it from a kid for $20 bucks, but it has been siting outside for years and was never painted. It has aloottt of surface rust but no rot. Iv have spent a good hour DAing with 80 gritt and it just wont all go away.
What sould i do? or can i just get it the best i can and coat it with self etch.??
Thanks Liam
Swims350
Logan WV
none
I did my monte carlo trunk that way, stripped it sanded it then hit it with self etch primer, then painted it. It lasted for a few years for sure. Might try some other method though, rust converter or something then self etch later?
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Yeah, I'd try some CLR or some Evapo-Rust first to chemically remove as much rust as possible.
Swims350
Logan WV
none
evaporust sucks, aint worth using. you have to submerge the part and keep it that way to work, kinda hard to do a door that way.
Now that purple power stuff c4 uses to convert rust may work.
I don't think I would trust that door enough to put nice paint on it. Those doors can be made out of some real low-grade metal and the damage may be too bad to permanently repair.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Soda blast may brighten it up. That Purple Power Rust Reformer is good for frames or other undercarriage but I'm not sure how rough it would make a body panel. Maybe after it dried it could be lightly sanded smooth and ready for primer, but if you did go that route I would prime it and keep it stored in a garage for a month or so and see if any rust creeps through. So far it has worked great for me but my truck's a rough ole cob.
86chevyk20
Buffalo
Liam
ehh **** it ill get a new door from LMC,, thanks guys
Swims350
Logan WV
none
hit it with self etch and see how long it lasts or epoxy primer.
jhngardner367
Lansing,Michigan
john
Newbie here.My name is John,and I've always used muriatic acid for cleaning rust from panels.Wear rubber gloves,as it's pretty strong. just paint it on with one of those sponge-type paint brushes,wait for 2-3 minutes,and flush it with water. It will even take the rust out of pitted steel. CAUTION!: It smells like rotten eggs,so use it in a ventilated area,and DON'T get it on skin!
You can get it at any hardware,i.e.,Lowes,in the plumbing area.
Swims350
Logan WV
none
aint that the same as naval jelly?
86chevyk20
Buffalo
Liam
Im not sure what to do guys, i want to buy a new one but at the same time i think its possible to save this one..
Worth saving?? or buy new one??
crazy4offroad
Curt
K-10
350/SM465/NP205
Try jhngardner367's suggestion above, sounds like he's done it before.
Swims350
Logan WV
none
save it. try the naval jelly, or acid stuff, rust reformer or whatever or just self etch it or epoxy and be done.
Just run with it and see what happens. I just wouldn't trust it if a show quality paint job is in your plans. What's your plans anyway? Spray paint, roller paint, cheap paint, nice paint?
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
I was thinking of the "shower method" where you set it in a big plastic tote and fill the bottom then use a sump pump and hose to continutally clean it. I've never done it before though, so I couldn't swear by it. Maybe you have?
imyourhuckberry
