Radiator Hose
AustinDube
1976 Chevy K10 Custom Deluxe
Maine
Austin
K10 Custom Deluxe
5.7L 350
So i got a 76 chevy k10 w a 4 speed sm465 manual. I got a lower and upper radiator hose but theres one on the passenger upper side that is plugged with a bot and 3 hose clamps, is that for what would be automatic transmission coolant lines? or am i missing something here.???
75Monza
Colville, Washington
K30, K20, K20
That is where one of the heater core hoses are supposed to go on mine, the other goes to the top of the intake by the thermostat. I've had some that hook to the water pump too.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yep. The trans cooler lines have flare fittings that thread into the radiator under the heater hose. I'm guessing someone bypassed the heater core because it got plugged up or leaks..?
AustinDube
Maine
Austin
K10 Custom Deluxe
5.7L 350
It doesnt leak so im not going to bother with it haha
Moderator Administrator
If it is the transmission cooler tank within the radiator tank that you're talking about then yes it's the Auto Trans Cooler tank. Since you're not using an Auto Trans, if you wanted to to do the plumbing, you could use it for engine oil cooler.
AustinDube
Maine
Austin
K10 Custom Deluxe
5.7L 350
That'd be pretty sick too
81k1500
