Quick question about the IAC valve
Burban1990
Vancouver, Wa
James
Suburban 2500
I'm going to replace my IAC valve with an AC Delco is there anything I need to know when putting in the new one other than resetting the IAC for during normal procedures?
Do NOT push or pull the pintle. if you ever must depress it manually, turn it in so you dont damage worm gear. Make sure to use a good o ring
Burban1990
Vancouver, Wa
James
Suburban 2500
So I've read about relearning for the IAC.
If someone with this experience could help. I just need to know about order of things I'm a little unsure. If I'm correct I believe I replace IAC then reset the idle and then afterwards relearn the throttle body in this order? I apologize for my ignorance I'm kind of new to throttle body. The last four square bodies I've owned have all been carbureted from the 70s. Also please inform me if I'm just overthinking it.
https://itstillruns.com/reset-baseline-idle-gm-tbi-7959677.html
https://ricksfreeautorepairadvice.com/gm-throttle-body-relearn-procedure/
Burban1990
Vancouver, Wa
James
Suburban 2500
I read to manually push in the pintle if it's sticking out too far before you install it. "Turn it in" could you please elaborat?
that is your valve yes? when its too far out, you want to twist... uh.. counter? i think when applied it clockwise extends, but when its retracted its counter or at least opposite. If you push it in it could damage the threads.
the 2nd one is for newer than tbi. like 2005+. the first one should be ok
Also what makes you think you need a new IAC? It probably just needs to be cleaned if you have EGR
Burban1990
Vancouver, Wa
James
Suburban 2500
I had a constant high idle and had to replace the coolant temperature sensor. After doing so the idle has gone back down to factory setting and the problem was fixed and it ran perfect. About a week and a half later I noticed the idle started surging and going up and down. I also replaced all vacuum hoses just cuz I found a few that were cracked. Last night I thought I would reset the idle to see if that would help to no avail. Then I started it up let it run for a few minutes to get warm unplugged the IAC and it ran perfectly fine as soon as I plug the IAC back in the idle started to surge up and down and then actually died. Over the last couple of days I had just noticed the fluctuation in the idol was getting worse.
Burban1990
Vancouver, Wa
James
Suburban 2500
And please correct me if I'm wrong but the spintle shouldn't be any further out than 26 mm?
Im not sure. my engines all relearn IAC on their own. I would turn it in mostly seated and try that
Burban1990
Vancouver, Wa
James
Suburban 2500
Turns out the IAC that was in it was an AC Delco. Wasn't gummed up or anything actually look pretty clean. Just went bad I guess! The throttle body was rebuilt not too long ago but either way I'm glad it's happy.
so its fixed?
