Question on the Comparison of a New, Quality Rag Joint to U-joint Coupler
Dejure
Eastern Washington
Kelly
C15
A new question I haven't found a clear answer to, after reading a lot of posts across several sites:
Would I see significant gain by going with a u-joint coupler instead of a good quality rag joint.
Every post I read talks about a huge improvement after a coupler was replaced, BUT, except where there are angle issues, the posts state there was a huge improvement indicated to be because the replaced coupler was failing. Accordingly, even a new, cheap rag joint would result in improvement.
Thus my question. And I am even more interested in knowing how much of an improvement I'd see using a double U-joint coupler over a rag joint because I am going to be going over the entire front end (shocks, ball joints, idler. pitman, tie rod ends, all bushing, and a new Redhed gearbox) and want my truck to handle as tightly as my old 69 did decades ago (it was great after the changes noted).
A third thing to throw into the equation. GM made different steering couplers besides different sizes and diameters. The made 4 ply and 7 ply. 7 ply was tougher and more rigid,manual steering got 7 ply,Corvettes got 7 ply and close ratio boxes got 7 ply. Personally I'd put on a 7 ply and call it a day. The reason for the rubber rag joint is to isolate sound and vibration from traveling up the steering shaft.
SquareRoot
I noticed a difference when I did the Jeep Shaft Mod. Kind of like the difference of an auto trans and a manual trans. It "feels" more responsive.
dd1990
Ventura CA
Suburban 1500
Why did GM get rid of rag joint and use a U-joint on the c3500 steering shaft? IDK, but what I do know is the u-joint offers better feel of the road, a bit more road vibration yes, but the slop is minimized.
stonchvy
