Quadrajet question
SugarCane
Louisiana
Justin
5.7L
Thank you guys really helpful. I'm picking up the 17080298 carb tomorrow. Plan is to swap over the choke and run it while I rebuild the 17085213. I'm going to pick up everything I need from Cliffs, seems like the place to go for quads.
Sent from my SM-N900V using Tapatalk
Carb'ed Vortec 350
Cliff will hook you up with a good kit just for your application. Just fill out his form with what you got, and what you may do in the future, and he'll walk you through what you need, i.e.: bigger jets/rods, whatever it is, he knows his stuff. And his kits are made to run on the new fuels.
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
Cliff does have the best parts available. And yes, you can pull the electric choke element off and transfer it to your new carb. Like mentioned, make sure you plug off the intake port or it will be a large vacuum leak.
Where is your old quadrajet leaking?
firebane
Calgary, AB
Curtis
Regarding the choke make sure it goes back on properly. I still haven't figured out how to line up all the stuff properly and its driving me nuts and there isn't a single good write up on how to properly hookup the choke levers and such.
MadOgre
NA
NA
NA
NA
NA
I could post some pics if that would help?
You can just remove everything as one piece and then its just a matter of getting the little lever on that goes from inside the body on the choke coil shaft to the actual choke plate. Its actually really simple if you use the right technique.
MadOgre
NA
NA
NA
NA
NA
Better off replacing the intake with an Edelbrock 2101. But ya for sure plug the tubes off that come out of the intake or make an actual block off plate for where the heater tube goes.
MadOgre
NA
NA
NA
NA
NA
I should mention that when you epoxy the primary fuel well set screws, that you have to be very careful that you don't tighten the set screw all the way down, or you will block off the main jet passages. Take a flash light and look down the main jet opening while at the same time tightening in the set screw(with out epoxy) and you will see what Im talking about. You will have to visually set the set screw in the right location while the epoxy is pliable. Otherwise you will turn your good Q-jet body into a useless piece of junk.
firebane
Calgary, AB
Curtis
easier said than done when the car was monkied with and you have no starting place.
SugarCane
Louisiana
Justin
5.7L
I'm not exactly sure. I'm am getting a pool of gas that slowly builds up on each side of the intake manifold directly below the center of the carb on both sides.
Carb'ed Vortec 350
Rebuilding it will most likely fix that. I doubt it's a design flaw that just popped up. There's a chance it was rebuilt before and wasn't setup properly, or it has never been touched and needs to be rebuilt.
SugarCane
Louisiana
Justin
5.7L
My guess would be never touched. Everything on this truck is original and untouched, just beat up. Even the original exhaust and mufflers are on it.
Sent from my SM-T530NU using Tapatalk
Carb'ed Vortec 350
If it were me I'd just rebuild it with a quality kit and swap in the electric choke. The electric choke works much better than the climatic choke. Mine used to run like crap, the climatic choke wasn't working properly, and the carb was just not right. I too thought it was all stock, but someone had rebuilt the carb at least once before. I got a quality kit from Cliff Ruggles, rebuilt it with a size bigger jets he sent with the kit, added the electric choke kit, and it now runs much better. Pulling hills is effortless now, whereas, before it needed more pedal.
SugarCane
Louisiana
Justin
5.7L
Funny how things work out. The guy I got it from already switched it over to electric choke, recently rebuilt it, and epoxied the well plugs. Not bad for $60.
350runner
tx
Ceasar
Now that's a good deal man. It's not often you find good deals like that.
Pics?
MadOgre
NA
NA
NA
NA
NA
The Epoxied plugs will leak again they all do. That's why you have to install the threaded set screws.
One other thing if any one does this fix, is that obtaining aluminum set screws will work better so that when the carburetor body heats up the aluminum will heat at a similar rate vs steel/iron set screws.
Blazer89
