QA1 Start
ROADKLL
albuquerque
Eddie
1980 short bed(Sold) Current is 74 C10
Well last night got the last pieces off, the upper control arm brackets. Rivets easy, top 2 bolt on each easy, the last 2 bottom bolts on each A PAIN. Headers all other stuff in the way. now to cut the spring perches out, clean, paint and assembly begins:)
ROADKLL
albuquerque
Eddie
Well it is now down to grease all of the new AQ1 rear and the QA1 front, bleed the brakes one more time and then a 4 wheel alignment. Only thing left is the front and rear sway bars. Will be a bit, all are on back order
ROADKLL
albuquerque
Eddie
To me, the perfect rake that i have it all set up at. Will have to let all settle for a few then go back to all four corners.
ROADKLL
albuquerque
Eddie
Got the greasing done and rechecked some torques. Pulled it out of the shop for a couple of pics, will be going for alignment on Saturday:)
I've heard nothing but good things about the QA1 stuff, you're gonna love it
ROADKLL
albuquerque
Eddie
Well Alignment done and sway bars on... LOVE IT!
ROADKLL
albuquerque
Eddie
Just some Halloween pics at a friends
cableguy760
Indio, CA
Juan
Roadkill can you give me some details on your rims and tires? I am Finishing up my qa1 and looking to get new rims and tires.
Rim size?
Back spacing?
Tire size?
Thank you.
C10SLEY
Chesnee, SC
Caleb
383 stroker
How do you like the rear brake conversion and what made you go with that option?
ROADKLL
albuquerque
Eddie
Rim size?
Back spacing?
Tire size?
Thank you.
Sorry for the 7 month late answer. Will get the backspacing for you. 18, Front is 18x8 and Back is 18x9.5.
You probably already gor the wheels and tires.
ROADKLL
albuquerque
Eddie
Love it. Hardest part was the proportioning valve, sucks where chevy put it:(
Rome03
