Puzzled
lopez2126
San Antonio
Joe
Siverado C10
Had a no start condition on my 85 C10, replaced mechanical fuel pump. Removed ignition coil for a visual. Looks brand new. Put it back in. As I attempted to connect negative battery cable I noticed some arching I continued. Fusible link at junction block started smoking. I quickly disconnected battery. Today I repaired the link with some 12 gauge wire. Still arching when connecting battery cable.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Do not compromise the wiring system by using wire in place of fusible link. Address that first or you'll burn your harness and/or truck down.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Check wiring to the starter. I'm sure there's a melted mess behind the passenger side of the block.
lopez2126
San Antonio
Joe
Siverado C10
Thanks everyone. Everything was fine 4 days ago when I took my truck for a drive. Then all of a sudden, it did not start. I’ll start tracing some wires tomorrow see what I can find…
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
That harness sounds like the culprit.
R Carnella
Long island
Rich
Suburban V2500
It's also possible a diode has shorted in the alternator. Disconnect the battery wire from the back of the alternator and see if the short goes away
wilson79
