- Feb 22, 2022
- Spartanburg SC
- Geoff
- C10
I pulled a problem child motor out of my 1980 c10 that I fouled and glazed during a cam break in with a stuck secondary carb needle.
This is weird and I need somebody to help explain it:
Pulled motor clearly has glazed/worn cylinders.
Pistons are .040 see picture.
On the side I pulled the heads, bores measure 4.005 on an Amazon purchased bore gauge. (Technically 103mm or 4.055 minus .050 indicated on the gauge).
Is there any way that the truck had stock bore and somebody put 40 over pistons in it? Is that even possible?
I’m not a machinist and so don’t really do this much, but I can’t make sense of this bore size and the pistons stamped 040.
I was hoping to just do a hone and rearing but the bore is…too small????
Any experience folks able to explain?
