Problem solving
Logan01
CA
Logan
I've got 2 problems and I'm not sure where to start.
First after about 5-10minof driving my lights start turning on and off and so do my windshield wipers. (Only if they are turned on by me first)
Second there is a wired sound coming from the engine bay at around 2000rpm that I can only describe as a light fluttering sound. It is silent at idle but there is a vibration that gets worse the longer you sit to take its place.
Thanks in advance for any help you provide.
Sent from my LM-Q910 using Tapatalk
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
The lights and wipers sound like a loose electrical connector or a ground that needs tightened.
Logan01
CA
Logan
It seems to me like something is overheating if I turn them off for a minute or two then it works fine for another 5-10min. I'll check my connections just to be sure tho.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Above. As far as the windshield wipers go, move to the western Texas panhandle....you wan't need em! I have chased noises and bumps from under the hood that turned out to be the little mud flap deals between the wheel wells and frame. They don't explain a vibration though??
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
That could be the light switch, they do that....again haven't ran any windshield wipers much since '92??
guillermoariast
