Kilian
- Mar 25, 2018
- Wisconsin
- K
- C2500 on its way to a K2500
Not sure of what forum this belongs in, so will start here. I'm going to add stock air conditioning to my 83 GMC with a 350, using the A6 compressor. Tonight when I pulled the brackets and compressor off a donor 1970s wagon at the local salvage yard, the power steering pump had a different bracket on it than what is on my truck currently. The bracket on the donor wagon has the adjustment slot on the far side away from the engine. The bracket on my truck doesn't have an adjustment slot, but is adjusted by another bracket mounted to the engine/driver's side exhaust manifold.
I'm guessing that I need to go back and get that bracket for the PS pump, or will what I already have work with the A6 mounting brackets?
