Power steering pump question
lothar863
Nashville TN
Colton
r3500
7.4 FI
1989 R3500 FI 7.4
Can i run another gm power steering pump that has an integrated fluid tank?
Craig 85
Nashville, TN
454/TH-400/NP205
I don't know if it would have enough capacity for the hydro boost. I'm assuming this is why they run the remote reservoir.
Big Chip
Michigan
Kevin
C35
Don’t the newer pumps have an integral reservoir? Seems like my 03 GMC did.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I'm just guessing,.. but I think it has to do with gravity and air. How do you get the air out of something as high as the brake booster when the sump is a foot lower?
HOTFOOT
northwest ct
michael
gmc k3500 srw
my 80 gmc k3500 400 sb srw has a integral reservoir
Craig 85
Nashville, TN
454/TH-400/NP205
Knowledge question for me to put in my memory bank. Does the 80 1-ton have hydro boost? I've only had 81+ 1-tons and both had hydro boost.
lothar863
Nashville TN
Colton
r3500
7.4 FI
I do have hydroboost and air bleeding i dont think would be an issue because air would still rise in the integrated tank once it gets forced through wouldnt it?
I want to replace the alternator bracket with one with a real tension adjustment other than pull on it and tighten which would require me to relocate the power steering fluid reservoir.
Has anyone relocated it elsewhere or used another tank somewhere in the engine bay?
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
If air rises it's going to the highest point in the system.
I'm sure you could locate the reservoir to another spot as long as you maintain the height.
HOTFOOT
northwest ct
michael
gmc k3500 srw
Yes, I should make a build thread as I am deep into this thing
Craig 85
Nashville, TN
454/TH-400/NP205
Here's a picture in a 68 truck, but I'm sure you could mount it on the core support or the L/F fender area.
lothar863
Nashville TN
Colton
r3500
7.4 FI
Looks like this one has the tank on the pump and it would be lower than the hydroboost
lothar863
Nashville TN
Colton
r3500
7.4 FI
As an Amazon Associate we earn from qualifying purchases.
boarder421
