Power steering belt part #'s ?
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Would anyone happen to know a part# of the belt that runs around the crank, water pump and P/S pulley ONLY?
This is for like 76ish to 87ish stock setups. The power steering pump pulley DOES have 2 groves in this case.
Gates, dayco, Advance etc. do provide part #'s but they don't have diagrams so it's confusing.
350runner
tx
Ceasar
What year is your engine?
Sent from my LGLS991 using Tapatalk
MadOgre
NA
NA
NA
NA
NA
Mine is a Goodyear Gatorback 15450 matchmaker 11AV1130 does power steering over the water pump and crankshaft pulley on 86/87 pulley set. It should be the same I think
350runner
tx
Ceasar
Yup that's the best one out right now.
fussfeld
east coast
j
c-10
4.3 v-6 262CID
The engine is an 86 4.3 v-6 BUT i'm using the original P/S pump to the truck which is an 83.
So the pulleys on the engine are the 86 vortech-ish setup with the ribbed belt for alternator. But i compared pulleys from my 305 that i replaced and pulleys look the same diameter as the 86.
MadOgre
NA
NA
NA
NA
NA
I have the same pulleys
fussfeld
east coast
j
c-10
4.3 v-6 262CID
UPDATE:
Ok, i got Dayco 15445 (Gates equivalent 7445) to work. i'm not saying these are the correct part# because both Dayco and Gates catalogs both list a different belt, but these do work.
Snips71
