Please help! Rebuilt 700r4 rolling while in park/all gears.
BlazerBill
Billy
Chevy K5 Blazer
I bought and installed a rebuilt 700R4 automatic transmission into my ‘83 K5 4WD and a new GM crate SP350 and am in the process of trying to start the engine for the first time for break in purposes. When I pushed the truck out of the garage to attempt a test start of the engine, I noticed that I forgot to shift it into neutral to push it out. Thinking the shift linkage wasn’t adjusted properly, I disconnected the shift linkage and found that the truck would roll (engine off) in any gear as I turned the gear selector shaft at the transmission. As a side note, the engine will turn over with key on in any gear but won’t start and I think I have isolated the no start to the HEI ignition coil which I’m currently replacing. What would cause the truck to roll in any gear? I’d appreciate your input! Thanks!
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Are you sure it’s getting into park? Is the transfer case in neutral?
It’s possible that you park pall is broken…
BlazerBill
Billy
Chevy K5 Blazer
I have confirmed adjustment of the shifter linkage with the shift shaft and it goes through each gear properly however I don’t know what it’s doing or not doing inside the transmission. Shifting feels “notchy”, as normal.
Chevy 88
Canada
f7t6
GMC
I know this is probably a stupid question, but you do have a driveshaft installed, right?
BlazerBill
Billy
Chevy K5 Blazer
Nevermind!!! What a brain fart. I’m so obsessed with trying to get the engine running, I didn’t think about that. Geez, sorry!!!
Robert Bare
MT
Robert
k20
lol.
Camar068
Air Force Supporting Member
Kentucky
10 yrs Air Force
lol that was a good one.:doh2:
xm20k
Girard, Ohio
Better that than what this guy forgot.
CubsFan79
