Please forgive me...
78C10BigTen
pennsylvannia
C10 BIG TEN
Very nice find. Congratulations.
You've probably already watched his channel, but Uncle Tony's Garage on YouTube does quite a lot with the slant. I really enjoy those builds.
Uncle tony has alotta good info!
legopnuematic
Licensed Junk Dealer
MO
Spencer
Hope everyone is enjoying their thanksgiving today, have made quite a bit of progress on the dart since I last posted about it.
At this point I have the fuel system complete, brake system complete and bled, It drove out of the garage and was able to make it around the block with it.
I have found a total of 3 Broadcast sheets in the car, one taped around the column, one under the front seat, and one under the rear seat, all match each other and to the car.
Here is the window sticker for it.
Got some big bolt pattern rallye wheels for it, blasted the faces and did a shade tree paint job. Some grey primer.
legopnuematic
MO
Spencer
Then flat black.
Then some metallic silver.
At menards got some stuff called D-germ, works pretty good on interior stuff to get the grime and stuff off.
legopnuematic
MO
Spencer
Designed and made up a gauge panel for it, will house a tach, oil pressure, wideband, and vacuum gauge, along with provisions for 3 toggles and pilot lights. Done on the Bridgeport at work
Threw a couple gauges and switches in for mock up
Got the tires mounted and balanced
Even with a terrible alignment, made it out of the garage.
legopnuematic
MO
Spencer
This is how bad it was with the wheel in the center, so got it close by eye
Will need a new Idler arm, it has a solid 1/2 inch of up and down movement, no biggie though.
I'm liking the look of the rallye wheels, need to get some centers and trim rings for them.
One of the many dirt piles to come out from under the car.
idahovette
Weiser Idaho
Perry
K20-K10
Just did and alignment for a friend with a 70 Swinger, NOT a mopar fan but it is still kinda cool. Anything this old still on the road and looking this decent, I like. His is a 360, torqueflight car in flat black. He's got the silver ralleys like yours. Nice little ride @legopnuematic
legopnuematic
MO
Spencer
Pulling the rear carpet up found a fourth broadcast sheet.
Got new bulbs for the dome light and the map light, got them installed and played with the map light switch and got it working again.
Started on the floor patching, just a homemade patch from 18 gauge.
need to plug weld it and a quick grind but the first floor patch is complete.
legopnuematic
MO
Spencer
Started on Floor patch #2.
The biggest thing this car is/was being attacked by is rust jacking, for those fortunate enough to not face rust on a daily basis, its when the rust is trapped between two spaces and literally jacks, expanding and pushing away from itself. Which makes for two really thin panels with a solid chunk of rust nugget in between.
Taco main chew
