plastic pins on door panels
bikerdave
the door panel push on pins on my 74 k10 broke. has anyone tried to repair these with success. the material is getting brittle and the pins broke while repainting. also the pins with the nut on them twisted off during removal. any thoughts. thanks.
FireTruck1984
Michigan
Ted
1984 and 1984
It’s unclear which pins you’re referring to… the trim? The plastic fasteners?
New push in fasteners are available through many vendors.
bikerdave
the molded pins that the trim of the door panel hooks to with a speed nut.
FireTruck1984
Michigan
Ted
1984 and 1984
In the absence of pins, 3M trim and emblem tape works really well
bikerdave
was thinking that or door seal adhesive
FireTruck1984
Michigan
Ted
1984 and 1984
Door seal adhesive would be a mistake, it often loses adhesion in extreme heat and cold.
