PaulCrawler78 92 Blazer
I'll bet someone stuck that tailgate emblem on there, it's not quite in the right spot either.
I bet someone stuck it on there too, cuz it hasn't fallen off yet.
It must be stuck.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Idk what is what but the DMV shows up as a 1992 Chevy that's all I know
10 Digit of the VIN tells the story of the year model and that's that. Towing cars, we have to put year, make and model on the forms. Many times we open a door to take a car, and we don't run plates, but know by the VIN what year it is.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Lol ya that's true.....so the truck has a 700r4 could my transfer case from my 88 k5 work with this truck for when I get ready to do a solid axle
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
not likely. the 92 is a pass side drop. you could clock the 88 to be in the right posotion, but the floor shifter rod would be a problem.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I can always fabricate a new floor shifter if that's the only problem I'll have when I go to do the swap but I have found a lot of axles from 4x4 chevys that are 6 lug in the junk yard com paired to the drivers side drop axles
Jims86
Patterson,Ca
5.7 TBI
Wait....your doing an FSA swap, right?
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ya that's the plan is to junk the front ifs crap for a solid axle up fromt
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Finally 1 thing went right it passed smog and will be in my name soon then off to the transmission shop to get the dreded TV cable adjusted properly
Yep, it'll work on the back that 700r4 just like it would on the old square. Shifter will be on the other side of the hump though.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Shifter don't matter to me I can always build a bracket to work with the 92 shifter just be reading wrong but I have a spare transfer case from my k5 that is rebuilt and more axles are available to me that have the passenger side drop on it
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Transmission shop said the 2-4 band is shot to **** so its 300 more to fix it
Yep, I Think someone said that a few pages back about the 2-4 band being the likely cause. Being it had Reverse, I figured it was. Otherwise, then it's the Sunshell Broke.
So WTF??? Are you saying they are charging $300 for a ******* band??? Or is this the whole repair job??? They're crooks if they're charging $300 for a band? What do they do, just take the part cost and multiply by 10???
Either your 2-4 Band is worn out, or slight possibility of Servo Seals which is not likely and uncommon, or Broken Sunshell. Sounds like the same Problem as Jim's Burb too. It's either the 2-4 Band or the Sunshell is broke. If Reverse was jacked up, then we'd know it was the SunShell.
I guess you didn't get to test drive it? But was told it was all good to go and drove fine?
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Its the whole repair job minus them pulling the transmission out
Jleopard77
