Parts(misc, trim, wire, etc...)
yevgenievich
Viktor
sad
very sad
less sad
AC/heater control panel, works but the fan selector switch broken on the tip. Still worked regardless. $10+shipping
vacuum selector valve with the hoses. $10+shipping
tbi from 350. With sensors and injectors. Came from a running vehicle. $50 + shipping
gmc steering wheel. In good overall shape. $30+shipping
90 cluster with electric spedo. Fully working when pulled(not sure about trip reset, that parts usually always does not work on these). $55+shipping
89-91 suburban passenger side (right) turn signal/running light housing. $10+shipping
plastic cover from a footwell fresh air supply. $3+shipping
cruise control unit - $10+shipping
tbi fuel lines. $5+shipping
gear shifter part that works on the transmission. $5+shipping
89-91 air intake mount box. $5 + shipping
85 computer. $5 + shipping
suburban door sills, full set. $20 + shipping
only back pictured, but front come with them
unrelated, but if anybody cares, full complete wiring for c5 corvette but no engine harness. - $30 + shipping
front blue seatbelts, dirty but usable. $20+shipping
3rd row blue seatbelts. a bit dirty, plastic cover broke the snap part. $20+shipping
ls ecm mount. $10+shipping
spicer one end of the driveshaft. Set for 700r4 ujoint size
front dash pieces, under steering wheel. $5+shipping
over steering wheel. $5+shipping
ac vent. $5+shipping
ashtray with housing. missing springs. $20 +shipping
dome light wiring. $10+shipping
suburban barn door strap. $5+shipping
tail light wiring harness. cut towards the front by the firewall. $10+shipping
blue suburban trim. $10+shipping
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
If you sell the drivetrain from that Firebird and I buy it, I will likely pick up the C5 harness and taillight harness from you as well if they aren't sold by then.
yevgenievich
Viktor
sad
very sad
less sad
do you have an offer in mind for the 350 TPI/700r4 combo with wiring and ecm?
One of the runners on tpi has a dent on it. It also has a holley throttle body on it. Shorty headers, accell coil. The only dtc that it is throwing is the speed, which is very understanding after seeing the seal tight spedo configuration. Transmission was replaced about a year ago on it with supposed to be low miles pullout.
This also would not necessarily be a fast take out.
yevgenievich
Viktor
sad
very sad
less sad
more stuff
mirror - $3 +shipping
suburban third row latch surrounds(only 3) - $3+shipping
license plate light - $3+shipping
th350 gear indicator - $2+shipping
yevgenievich
Viktor
sad
very sad
less sad
Condenser and evap cores in good shape. $20 each+shipping
yevgenievich
Viktor
sad
very sad
less sad
Cab corner and window guides for front doors. Have the other cab corner, but it has a 4x4" piece cut out on the flat part.
Cab corners - $15+shipping
Windiw guides - $15+shipping
yevgenievich
Viktor
sad
very sad
less sad
suburban door sills are sold. Everything else available.
yevgenievich
Viktor
sad
very sad
less sad
Gauge cluster sold
Price drop:
Mirror -$1+shipping
suburban third row latch surrounds(only 3) - $1+shipping
license plate light - $1+shipping
th350 gear indicator - $1+shipping
Above four items together - $2+shipping
yevgenievich
Viktor
sad
very sad
less sad
I will still take the C5 harness and the taillight harness.
Will consider sold, and if you want most of body wiring from 2000 silverado, then it is included with the corvette body harness.
yevgenievich
Viktor
sad
very sad
less sad
Make an offer on complete 1990 suburban wiring with 85 headlight wiring instead of 90? And partial 85 cab harness?
throttle out
Michigan
Sam
5.3 LS
Could I get a price for the window guides and the steering wheel shipped to 48118?
Thank You!!
yevgenievich
Viktor
sad
very sad
less sad
Pm sent. Tbi unit sold
yevgenievich
Viktor
sad
very sad
less sad
700r4 torque converter cover
$2+shipping
also found the needle for the shifter indicator
price drop on ash tray $4+shipping
mattyb
