Parking brake pedal will not compress
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Hello ladies, gents.
Parking brake hasn't worked the same since the lift was installed last spring. Now I know what you're thinking, "you put a lift on it, need to make adjustments", etc. I agree, yet the cable running underneath the truck isn't as tight as you would think it would be. And the rear wheels move freely cause it isn't applied - that's no problem
But the parking brake pedal, you go to push it/engage it and you can't even get a click out of it. What the hell am I missing? I've tried putting my peepers on it but you know how much room there is. Hard to know what you're looking at unless you've got a diagram present at some point.
Parking brake systems have never been my strong suit, be gentle.
(On the '74)
ali_c20
Austria
Alexander
C20, K5
(On the '74)
That would be my approach: Loosen the adjuster as much as possible so that the brake cable has no tension on it. Remove the cable from the pedal. This is PITA and you will swear a lot. Step on the pedal. Pedal moves: Cable is seized or some other problem below the pedal, continue searching. No move: Pedal is the problem, remove from truck and repair.
Chevy 88
Canada
f7t6
GMC
Who installed the lift? Is the parking brake cable disconnected?
ali_c20
Austria
Alexander
C20, K5
(On the '74)
Just came to my mind: Is the pedal pushed in all the way? With a lot of slack in the cable it would not actuate the brakes as the foot pedal does not have a lot of travel.
That would explain why it doesn't move. Happens to me sometimes that I overlook the obvious.
fast 99
Spokane, Washington
^^^this^^^
If your a larger person take the seat out, only 4 bolts. It is more likely that one or more cables are stuck.
duncan_schawalder
