Parking Brake Cable Guides-1978 K10
shep151
Columbia River Gorge
I've been searching the forum for the answer, but I can't see it anywhere...
My Intermediate cable failed at the boat launch this week. Unfortunately, I was unaware that the cable guides were not solidly attached by design, so when I arrived home after a 100 mile drive, I have no left or right cable guides. The front right (inner, part 10 on LMC's diagram) cable guide made the ride, thank goodness, but I need to replace the outer guides.
LMC shows NO cable guides for pre-1981 K series trucks. So my question is, how different are the guides, really? And to get the closest match, should I buy 1978 2WD cable guides, or 1981 4WD cable guides? From the crappy design, I may end up making my own replacements this winter but I do need a quick fix, since I really don't like resting 10000 lbs on the tranny at the boat launch...
Thanks for any wisdom anyone has to share!
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I thought for sure I had a good picture of the parking brake cable and brackets but Here’s the only picture I could find.
73 cheySuper
beaverton
jerry
cheyenne super C20
From that pic it appears the 4 wheelers have a shorter loop and a longer single pull to the pedal pulley.
Old Guy Bill
KY
Bill
Here's my '78 K20 with a later NP208, which is longer than the original 203, and dual exhaust.
The rear ones are originals, both front are fabbed.
"Have Redneck Will Travel" :)
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
Here's my 73, hope it's helps you get it back together.
straydog371
Army Law Enforcement Supporting Member
WNY
Kerry
Maybe what you're looking for?
hauto85
