Optimal engine temperature for max HP?
Edelbrock
Earth
Grumba
K5 Blazer
So lately there have been some posts about engine temps.
I wonder what the optimal temp would be for max power on a Chevy 350 or 400.
Fuel mileage and emissions are not a factor in this, just pure HP
Any ideas?
xm20k
Girard, Ohio
Coolant temp plays a very small part in performance air charge temp and cylinder temp are more important.
This is why intercoolers are a thing on forced induction.
As is water meth injection.
As well as scoops and external ducting for Na engines.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
A better question, that I've never seen answered, is what is the best ambient temp? Plus factors like elevation and humidity and barometrics.
We all know colder temps make more power, but how cold? What's the point where it starts hurting performance? 32F? 40F?
I always wanted engine masters to test this, but that's not really a dyno possible activity unless there's some multi billion dollar military testing dyno that can simulate elevation and atmosphere changes.
Something I've thought about on and off for the last like 15 years lol. Never really looked into it though.
Edelbrock
Earth
Grumba
K5 Blazer
I wonder if you could make a cold air intake that incorporates liquid nitrogen in some fashion. For example, if the liquid nitrogen circulated through a small radiator that covered the intake for the engine, super cooling the air that going into the engine. This would not be sustainable of course, but for a a drag race it might work. Or maybe using dry ice in some way. Would getting the air intake temps down to zero help much with power?
xm20k
Girard, Ohio
I think at a point it just doesn't do anything to improve performance, the engine even where force induction is concerned just can't pack in more air, but other stuff may become an issue, like things getting brittle from the low temps, fluids starting to freeze or thickening up etc.
xm20k
Girard, Ohio
Latent heat of vaporization as air and fuel are drawn into an intake manifold can drop the temps in the manifold to just over the freezing point in a perfect scenario, but in a vehicle under a hood in the real world you can only do so much before cost, space, and weight become issues.
saturdave__
