one piece or two piece vent windows?
Jwernatl
Senoia, GA
5.7ltr
hey all - can anyone look at the pics and tell me if I have a 1 piece or two piece vent windows? I'm abou tto replace all the rubber
Octane
Atlanta
Eddie
Looks like mine.One piece run down the small post .Other piece run around the rest of frame.I replaced mine years ago.Didnt enjoy it but got er done
eskimomann209
Modesto
Marcus
Looks like a two to me.
Octane
Atlanta
Eddie
I ordered the kit from LMC.It didn't have the rubber piece that holds the glass itself inside the frame groove.Some will seal it with silicone there but I never have.I wd-40 the channel the bigger rubber goes into and it was still stubborn.Riveted that vertical post rubber on.A glass man told me they charge a good bit to repair vent windows...if you find one that will do it.He said it was a $500 job but couldn't get that much to do it tho.lol
eskimomann209
Modesto
Marcus
I usually use the silicone line spray and some heat if I’m really struggling. I guess I’m also an outlier that uses a screwdriver.
your thumbs will hurt for a few days after the jobs done LOL.
Jwernatl
Senoia, GA
5.7ltr
so ya think it is a one piece?
Ive had a few say it was a 2 piece.......urrrrghhh
Bennyt
Surprise
Ben
It's hard to tell with your pictures. It's difficult with any pictures as they look the same until you take it apart.
Rebuilding vent windows is time consuming and is difficult to do without wind noise. I'd pull one, take it apart and order exactly what you need. LMC only takes 2-3 days to get parts.
If you don't want to do the job, PRP rebuilds vent windows. They dissasemble, powder coat the uprights, replace the glass, seals, etc and guarantee the job with American parts and labor.
Moderator
Due to the curve at the top corner of the glass, I can tell you they are 80's design and not 70's design. Couldn't say about the seals though, I've never replaced them.
eskimomann209
Modesto
Marcus
It’s not hard to tell. the gasket will go over the window pivot on the single piece designs.
On the two piece you can see the pivot bracket as it attaches to the frame.
eskimomann209
Modesto
Marcus
This circled part. The metal bracket would be covered by the gasket of it was a single piece. My trucks a single. But I’m a few hundred miles from my truck RN.
Slybeanx
Maryland
R1500
v6
I did one vent and it was a PITA. not looking forward to doing the other one, but it is needed with how cracked mine are.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
youv got a 2 pieces...one piece got the rubber outside your door panel did a post on that! :)
The Right side of Washington
Timely thread! Just took my vent windows out last night. Have the new seals, gonna be a side job while I'm re-doing the rest of the truck....yay.
Obviously window comes out. Presume drill bracket rivets out of frame vs drilling out the single rivet that the window pivots on? (thats what the utoob guy did, lol)
Question, do you have to drill out and split the 2 pieces of the frame to replace the seal, or can you leave the long straight window track attached to the other piece?
I forsee having way too many hours into these goddamn things by the time they are apart, cleaned up and painted and re-assembled.....
rafamartz
