Oil sensor port
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
I can't get oil to stop leaking from the oil sensor port on the back of the motor. I have used thread tape with no success. Looks like I'm going to have to pull it out again, and use sealant this time. Problem is that I have to pull the distributor in order the get it out.
Anyone have this issue? How tight did you have to get it? What fixed it?
Dripping oil is getting very annoying.
Thanks in advance.
Brandon
CSFJ
Are you positive it's coming from the port and not the sending unit itself?
1973c10
Don
Or from the back of the intake
I have seen them leak there
1973c10
Don
Is it a sending unit or a line for a mechanical oil gauge
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Definitely not coming from the unit itself as it's a brand new piece from Dakota Digital.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Hmm, I suppose it could be coming from the back of the intake, but I'm almost certain it's the oil port. I can see and feel oil from the 1/4" extension that I have coming from the port.
1973c10
Don
What is the extension made out of
if its brass could it be cracked ?
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Brass. I'm going to pick up another one in the event that it is either cracked, or just not working. This time around I'll put a good amount of thread sealant on and hope that works.
Oil does oil come out of the intake manifold gasket? I'm new, but trying to understand how that would work.
CSFJ
Yeah, the intake gasket set is typically in 4 pieces. The front and back are rubber seals the are notoriously difficult to get to set correctly. Very common to get a leak at the back.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Gotcha. I watched a You Tube vid and the guy actually threw those rubber seals away and just put a 1/4" bead of RTV in place of those. He said they were notorious for leaks.
CSFJ
I've heard of a lot of people that swear by using rtv instead. I got thinking about it last night. I've never had a small block leak from the intake and I've always used the gaskets. The only reason I can think of, is that they were all assembled on engine stands, where I was able to get close enough to set the intake squarely down on the block. Dunno, maybe it was just blind luck, maybe it has to do with being able to make sure it gets set down evenly and squarely.
Georgeb
Wisconsin
George
K10 Burb Z71
I have also had no problems with the rubber strips. I did use Gaskasinch to glue them down to the block and a dab of anaerobic sealer on each end for mine. I did do the silicone thing on the last intake I set with no issues as well.
80Steuck
Minnesota
Kevin
Dumb question but u said u pull your distributor every time to work on it. Is the gasket still on your distributor or is it torn possibly. Have seen guys forget to put one in before
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Yes or they don't realize the dizzy has a gasket and when you pull it out it falls off and drops to the ground never to be found again lol.
