oil pressure sending unit
flatford39
NE Illinois
Tom
K2500
My oil pressure gauge isn't working. It's stuck at 60PSI. I was trying to find the sending unit and my service manual tells me it is on the left front side near the distributor. I don't see it. Shouldn't it be in the block somewhere. I take left side as drivers side of car.
The truck is a 1980 K10 with a 350 in it.
Can anyone help???
Thanks,
Tom
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Left rear corner, on the driver's side.
Behind the head.
1/8" pipe thread.
Tight spot to reach in to, but not impossible.
Skweegle89
Oklahoma
chengny
A little clarification on sender vs. switch. Also, if you can't find your sender behind the distributor, look down on the side of the block just above the oil pump. I think that is where the were located in the early 80's:
sever
