NV4500 Swap - Clutch/Hydraulics Dilemma
nujac
texas hill country
bruce
k20
I do not know if it is just me but the 5 speed in my 95 F150 with a straight six seem to have a better over all gear ratio between gears than the NV4500. I am only running BFG 33 " I need to have my local drive line shop drive it to see if they would recommend a rear end gear ratio change. I think some nv4500 have different ratios between the gears.
Preston Tucker
Maine
Preston
@bucket do you know if a dodge nv4500 can be used as well or are there shaft differences?
Moderator
I'm certainly not an expert, but I believe the input shaft is different and the output shaft has a different spline count.
SquareRoot
Dodge vs GM are different diameter and spline. The shafts can be swapped if 95 and later.
Preston Tucker
Maine
Preston
@SquareRoot @bucket Can i use any GM nv4500or is there a certain year range that i need to find? I assume 4x4 is differnet shafts than 2x4 as usual.
SquareRoot
The 92-94 GM are different than the dodge. After that they are the same. 2wd vs 4wd doesn't matter as far as shafts. A 4wd will have a different rear tail housing. 4wd bolts to a 6 bolt round pattern t-case, 2wd has a slip-yoke tail housing.
Preston Tucker
Maine
Preston
I want to nv4500 swap my lifted k20, what is the one that i want? Will any gm one work or do i need a 4x4 within a specific year range, i know they used them all the way up untill 2007.
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
When I was researching doing NV4500 swap into my 77K10 I found that AA has a great tech page on the NV4500. May help you out.
SquareRoot
By far the easiest solution is to call Advance Adapters and tell them what you have. They have complete packages. Everything will be new and/or rebuilt. It's not the cheapest option but it will save you months or years piecing it together and rebuilding used parts.
mrgoodwrench
MN
mike
silverado
Nothing against the AA kit. But im in the process now of swapping a late model nv4500 in place of my 700r4 (more work than your swap) you can run you current master cylinder and the late model slave cylinder by using this hose. https://www.summitracing.com/parts/ear-64191936erl and these 2 adapters. https://www.summitracing.com/parts/ear-ls641001erl https://www.summitracing.com/parts/ear-592054erl. on it just an option.
Also know that the 2001 2500 hd may have a slightly taller top shifter plate and shifter knub and this will plache the shift handle and knob higher. This is because the hd of that year had a factor body lift. This is what i have been told. And i have not completed my swap yet so take my info with a grain of salt.
I get external slave is easy maint but a quality internal slave should last a long time usually longer than the clutch and just replace it when you do the clutch as maint. My daily driven chev cobalt has internal slave and im on origional slave and clutch 15years and 265,000miles so far.
Sent from my SM-G970U using Tapatalk
eskimomann209
Modesto
Marcus
The fitting goes into the bottom of the masters with that little roll pin?
mrgoodwrench
MN
mike
silverado
The fitting threaded on both ends goes into the line hole on the master then attaches to the hose listed then the other fitting goes on the other end of the hose and will attach to the quick disconnext on the internal slave cylinder.
eskimomann209
Modesto
Marcus
How would one adapt to this style.
mrgoodwrench
MN
mike
silverado
That i dont know usually square body suburbans used this style.
Yours looks like the later style maybe?
eskimomann209
Modesto
Marcus
The master itself is indeed. The throw out is from the 05 nv4500 and has a similar fitting on it.
I seen the master on the 05 has that same roll pin line lock. Gotta be something out there to adapt to it, I’d think.
76Dump
