I can’t emphasize strongly enough what an absolute disaster the NV4500 actually is…
1. Weak (fragile) synchros
2. Very expensive proprietery gear oil
3. Can’t tow in 5th
4. 2-3 and 3-2 shifts have a HUGE rpm drop
5. 1st is absolutely useless in the internal slave cylinder version, unless way over its duty rating, in the mud
6. No real drain plug, take out a pto cover bolt, when it quits dripping, pull pto cover and mop out another 1.5 cups of goop
7. Damned near impossible to refill in a 4wd or if you have passenger side exhaust.
8. The BW t-case that goes behind it is 1000x worse
My 99 K3500 c&c is getting an SM465, Ford NP205, and a carburetor swap. To correct its built in flaws. Already disabled the ABS…
