NP208 case internal help
midnightblue
western PA
I am installing a slip yoke eliminator from Tom Woods driveshaft. My main shaft has a hole that a (pin/roller ??) sits in that appears to lock the washer? It fits loose in the hole. The cut down main shaft they sent me does not have a hole it. I looked at a breakdown in the service manual and do not see the "pin/roller". So my question is does anyone know how important is this "pin/roller"? I would love to get this back on the road while I have time to work on it. Thoughts?
original main shaft
This is during tear down with the pin/roller removed already
new main shaft without the hole
Pin/roller
I'm curious to know the answer. Did you by chance call Tom Woods?
SquareRoot
That pin keeps the thrust washer from spinning. If the fixed yoke is secured by a nut, it may not be needed any longer. I would ask the vendor about it for sure
midnightblue
western PA
No, I received the shaft Friday night, by the time I switched everything it was Saturday and (good for them) they are closed on the weekends. I will give them a call Monday AM. Since I do not see this pin/roller in the parts diagram and they do not mention it in in the manual, I am going to complete the install so I cab drive the Blazer Monday.
hopefully you are correct :)
thanks for the replies.
midnightblue
western PA
UPDATE - So I completed the install, took out the transfer case drop and shimmed the rear axle. No more low MPH vibration. Put about 100 miles on it and everything seems great. I e-mailed Tom Woods d/shaft with pictures and questions. They called me today and explained that 1/2 of the main shafts that they do have that pin and the other half do not. They did not want to go as far as to say whether or not its need or not and offered to do mine if I was concerned. I elected to just go without it. Either this winter or next year I will be rebuilding the transmission. I will have a look at the TC at that time to see if that area is wearing/damaged.
FenderBanger
