No electrical power all of sudden while driving
Arroyo083
La Habra
C20 Camper Special
So I pull out of a parking lot and give it some gas because it was an unprotected left hand turn and traffic was coming. My truck died, no lights, no power, nothing. Luckily I coasted to the nearest parking lot. I checked terminal wires, there’s spark at my starter… I tried jumping it, in case it was alternator but nothing. The positive at the alternator looked to be a little severed but not a deep cut. It was touching part of the alternator bracket. I separated the wire from the bracket, but nothing. I’m reading here and other places that it could be my fusible wire? It doesn’t look toasty but I see it can not look burnt and still be burnt. When I turn my key I have absolutely nothing, no lights on dash, no head lights nothing, as if there’s no battery in it. Could this be the fusible wire?
The battery is about a month old. Truck has started perfectly since I’ve had it. Any help would be appreciated. Thank you.
Rickf
Grafton NH
1974, 1954 & a 1937
My vote is for a fusible link. Repair or replace the alternator wire first.
Lift3d1
California
erik
c1500
I'm having the same issue! never had a problem and then out of nowhere its dead! what did you do to repair it?? do you think cold temps had anything to do with it?
thank you!
