mtnmankev
- Jun 10, 2014
- Ash Fork, Arizona
- Kevin
- K10, C20
- 383 Stroker, 350
83 C20
Once upon a time, I would turn the lights on, they worked until I hit a small bump in the road, then the fuse blew.
Replaced fuse, everything worked again until I hit another bump.
Later, I replaced the headlight switch because all the lights started acting up, and the new switch fixed that.
The lights worked fine for about a month, then the fuse blew again.
Also, cig lighter lost power.
Replaced fuse that was blown, all other fuses are good.
Cig lighter never did have power again so I had to find another power source for it, and the dash and tail lights still won't come on.
Have tried six headlight switches, and all I get is headlights.
Bulbs are good, grounds are good, the connector into the back of the instrument cluster is snug and the connections are clean.
I am at my wit's end trying to think where to look next for the problem.
With summer here, I need to be able to use the truck for night driving when it's cooler.
