Newbie's ideas
pbritchie
Forsyth, GA
Presley
First off I got a 85 K10 with atleast 9 in of lift already. The motor, minus some electrical problems that are getting worked out now, runs good and I aint got no complaints with it. As for the ideas well take a glance.
Buying 1 ton running axles in the next few weeks and going to get them prepped to go in the truck ASAP.
Want to find a 700r4 and rebuild it and throw it in as well.
Looking to do some stuff to make the interior nicer
Re-paint the truck from poop brown primer to a charcoal grey.
Crossover steering with a hydro assist kit to help turn the 38's no problem driving around school.
Got to get the heater hooked up cause I will be using this as a daily driver during the winter months.
If yall have any opinions on what I could do to make this a solid daily driver/fun weekend bogger it would be much appreciated. Im in the Marines currently and got to have it a little more comfortable in the next few months for when I get out and go to school.
Swims350
Logan WV
none
find a different transmission to put in or absolutely build the guts out of the crap 700r4.
pbritchie
Forsyth, GA
Presley
What other trans would you suggest? I wouldnt have a problem with the th350 but everyone around says that its **** and go with the 700r4.
animal
Lee
c10 silverado
350ish
Howdy neighbor:wave: Welcome to the site.
pbritchie
Forsyth, GA
Presley
Hey and thanks. I def think this site will help me a whole lot...everytime I open up a new thread I learn something new...as well as want to spend every dime Ive saved up to get my truck as nice as some on here
Welcome to the site man. Sweet rig. :wave:
f1shman
Everything is bound to break sooner or later. Likewise, everything can be built stronger than stock if your wallet is thick enough. Strictly speaking in stock configurations though, I'd list the transmissions that came in square bodies from the factory in this order: SM465>TH400>TH350>TH700R4. Do note that this is my opinion on the matter and I can not give you a factual reference to back this list in any way. The only way that I would put a 700r4 in my truck is if I was driving on the highway with it daily and I needed the extra mileage from the overdrive.
Unless your going to run 4.88's or 5.13's with those 38's, overdrive won't do you any good. It will just lug the motor down too much without some steep gears.
pbritchie
Forsyth, GA
Presley
Thanks guys all the advice helps with this build! I guess Ill tear down my th350 and build it stronger...probably going to be the cheapest route anyways.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
If your pockets are deep (assuming this because you want to swap in tons asap) and you MUST have overdrive look into a 4L80e. Personally I see nothing wrong with a TH350, many people use them for the mud races around here.
pbritchie
Forsyth, GA
Presley
Pockets def arent deep just got back from Afghanistan and looking to do some mods while im home on leave. Yea talked to a buddy and Im almost certain that just rebuilding the TH350 is the way to go for my budget. As for another question...a guy back from home is selling a FF 14 bolt rearend with lockers and 4.56 gears for 400 bucks...came out of his k10 since he is going to 2 1/2 ton rockwells...they look decent enough. Worth the 400 bucks?
crazy4offroad
Curt
K-10
350/SM465/NP205
I paid $150 for mine, put disk brake conversion on for $150, put 5.13s in it for $350, and a locker for it had I got one would have been another $350 (Yukon). I just welded mine though. So yeah, as long as it's in good shape as far as the gears and locker goes, it would be worth it. See if you can get his driveshaft too, depending on how much lift he's runnin. Yours will more than likely be too short.
pbritchie
Forsyth, GA
Presley
Where did you find a disk brake conversion? Not anytime soon but down the road that would be something to look into.
crazy4offroad
Curt
K-10
350/SM465/NP205
LOL Off Road Designs, they've gotten a lot of my business. You just use 1/2 ton or 3/4 ton (same thing) front calipers. After I already had mine I heard there were cheaper alternatives though. Shop around, you might score it for around a yard.
pbritchie
Forsyth, GA
Presley
Damn I can already tell my bank is going to be drained into this truck...oh well though at least she will be fun.
Smik
