Newb wiring question
rcamozzi26
Paradise
Ryan
This is my first square body truck I’ve had 6 silverados but never anything this old so there’s a lot of things I don’t know yet. Just picked up my first truck a couple weeks ago and so I’ve been slowly working on it. Anyway there’s a toggle switch the previous owner installed in the dash and two wires run out to
what I think is the windshield motor? It’s the two blue wires in the pic and the toggle switch seems to be broken. Any help on what it’s for or why they did it is appreciated. Just wondering if I can ditch it
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I think you're right that the po has that switch for the windshield wipers. The po of mine did the same thing but with a wall light switch. Lol and it runs my wipers.
Gonna have to fix that sometime. It does work as gay as it looks tho. Lol
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
rcamozzi26
Paradise
Ryan
But the stock one works and I’ve played with it turning it on and off while the stock one is one and it changes nothing. Could it be some kind of jumper wire but the switch is stuck on?
rcamozzi26
Paradise
Ryan
here’s the new project. 73 with a 350 that won’t be in there for long I hope. Gonna get full cab off restore and hopefully 6.0 ls swap when it’s done. Pretty solid truck no heavy rust and pre smog for California[emoji14]
Snoots
Roger
Jimmy Sierra
Looks like the 'pulse' option and they gave up trying to fix it so they hot-wired the motor to the oddball switch.
rcamozzi26
Paradise
Ryan
What’s “pulse”
sdewolfe
New Caney, TX, USA
Shannon
I can't see where the added blue wire goes when it leaves the picture. I am going to guess that is going to the windshield washer pump. But I am more concerned about the bulkhead terminal block than I am about the washer/wiper splices. Look at the right side of the connector. You have some major heat issues there caused by dirty/corroded terminals.
Doug, your wiring is scary.
TJinAZ
