new to forum
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
Hello
I have a '76 K10 Bonanza with a 400 that belonged to my father-in-law. He bought it new back then. The truck served as a farm truck towing hog trailers for about a decade, then as an irrigating truck until about 15 years ago. It has basically sat still ever since.
The history is a bit fuzzy from what he can remember. It had a new engine in '81 after the original blew, and that rebuild blew almost immediately, then a replacement was installed and that has been in there to this day. The truck is on it's third or fourth TH350 transmission. The old adage of heat kills the TH350 plays true here, towing 10,000 lbs trailers for eons was not kind to them.
I have cleaned up the truck, original paint, and changed all fluids, replaced all underhood rubber, all vacuum lines, new water pump, hoses, belts, thermostat, oil caps, valve cover grommets, pcv, and tune-up items. Also had to get the radiator rebuilt since sitting for so long corroded the innards with crud. I still need to get the Q-Jet rebuilt and get an exhaust leak fixed. It has true duals though, so it sounds great.
All this engine work has made a huge improvement in drivability overall so far.
Plans include a mechanical restoration at this point, left to do: restoring suspension bushings, shocks, brakes, steering and ball joints, etc. (steering is loose) Fixing rust and interior come later. Though I did have to recover the seat with walmart vinyl already.
Will also get a new intake and cam for more low end torque eventually. Probably address temps with auxiliary trans and oil coolers.
Also how many photos can i upload to the site? I have several detailing the process so far.
Shorty81
Baby Boomer
North West ohio
Darren
Welcome from the Buckeye State. Nice Bonanza!
RoryH19
Rory
R10 Silverado SWB
Welcome from TX.
Nice truck.
WFO
Texas Panhandle
mcarlo86
ND
Suburban
Nice truck! My uncle in SD hauled hogs for many years with a '78 K15 GMC similar to your pickup. I think he put well over 200K on it before the body finally rotted out and he retired it. You may want to start a project page for your pickup and post as many pics as you can. We all like to see pics and appreciate following your progress. Welcome to the best square body forum. Great people here and lots of great info!
:welcome:
Snoots
Roger
Jimmy Sierra
350 w/203
animal
Lee
c10 silverado
350ish
:welcome:
1973c10
Don
Welcome from Oregon
Hard
