New here..
Martimus
Michigan
Marty
Looks to be a great site, lots of good build threads and stuff.. I have a 91 4wd burb but the tub is pretty well shot. I just got a 87 C10 2wd cab and long bed to clean up and put on a long bed frame and use the running gear out of the burb along with the 91 front clip. No frame yet, but no hurry or worry as the cab needs some serious work on the bottom side before it can go on anything.. Cab mount bolts broke off in it and 1 nut spun inside so I'll be opening all that up to fix and use rubber plugs to cover the holes. Some rocker work and misc patching, it's not too bad..I chose the 2wd cab deliberately so there's not so much of a trans hump on the floor, and I'll have to do a 3" body lift to clear the running gear, plus I will eventually need the clearance. Burb has a 6" Rancho all-spring lift with dual shocks in the front, so that will all go on there.. Unless: I go insane and decide to section the long bed and put it on the burb frame - not likely though :)
animal
Lee
c10 silverado
350ish
:welcome:
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Welcome. I like the burb
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
WFO
Texas Panhandle
:welcome:
1973c10
Don
Welcome
tnahaus
