samg1730
- Nov 2, 2016
- texas
- sam
- C1500
- 383 Stroker
New Guy, New Truck, crappy Dyno #s....
Hello folks, have always love the square body GM trucks, finally can call myself an owner. Recently purchased this 85 GMC short bed with 383 stroked motor and 700R4. Guy wanted $800 with a clean title so I jumped on it. The previous owner told me that the engine had been a not-original 350 when he purchased it. He claimed to have had it bored to 355 and added a crank, pistons and cam taking it to 383.
Bolt-ons appear to be a 600 CFM Edelbrock carb, Edelbrock intake manifold, Thorley headers going to 2 mufflers that end right under the cab.
Since purchasing I have:
-08/16-
Torque Converter (reconditioned)
Transmission Governor Assy
Driveshaft rebuilt
-07/16-
Flywheel
Battery
Starter Assy
TV Cable
Shocks
Alignment
New Rotors and Calipers
-06/16-
Transmission Rebuilt (seals, mount, pump, gaskets,o-rings, filter, etc)
Transmission Cooler (aftermarket)
Wiring Harness
Speedometer Cable
Ignition Switch
Blinker switch
Spark Plugs
Valve Cover Gaskets
Valve Cover Hold-downs & studs
Timing Cover
Control Arm Bushings
Sway Arms Bushings
Upper A Arm
Tie Rods
Wheel Bearings
Air Filter
So after completing the above jobs I took it to have it Dyno'd. I pulled only 179HP and 268TQ. I will add the graph once I can find the slip.
SO WHAT GIVES? I was expecting rather low, but man! The gentleman that did the dyno said that the TQ numbers were indeed indicative of a stroked motor but that it could be breathing problems that are resulting in the low HP. Then of course he recommended I junk the carb'd engine and go straight to LS 5.3 Swap.
I am in serious need of opinions. I have about 5k -6k budget on just the engine and am hoping to reach the 400HP mark. What could possibly be giving me such low numbers?
THANKS!
-08/16-
Driveshaft rebuilt
-07/16-
Flywheel
Battery
Starter Assy
TV Cable
Shocks
Alignment
-06/16-
Wiring Harness
Speedometer Cable
Ignition Switch
Blinker switch
Spark Plugs
Valve Cover Gaskets
Timing Cover
Sway Arms Bushings
Upper A Arm
Tie Rods
Wheel Bearings
Air Filter
THANKS!
[/URL][/IMG]
[/URL][/IMG]
