New Carb Swap
Mikedbnt
Columbus
Michael
C20 Cheyenne Trailering Special
Hi all I recently bought a 1975 C20 Cheyenne Trailering Special. I'm really excited about it because I have wanted a truck like this for a long time. I'm younger and don't have a lot of experience with carbs, but that's part of the reason I bought this truck because I wanted to learn.
Before I bought it, the truck sat for about 10 years. Since then I've been replacing a lot of items, brake lines, hoses, belts, etc. It has the original quadradjet but the accelerator pump leaks bad and it was seeping fuel from the bottom of the carb too. I bough an Edelbrock 1406 (600cfm) carb to swap on the original manifold. I want to replace that too but I just wasn't ready to spend the money yet. Although if its better to just replace them both I think I can make it happen.
The issue I'm having is that after I put on the adapter plate and got the carb set on I needed adaptors for the transmission kick down and throttle cable. The adapter bolts to the back of the manifold where the original mount holds the cables. (not the mount on the back of the original quadrajet) Maybe I'm missing something here but of the tools I have I can't seem to get to the two bolts to remove that original bracket so I can put on the new one. What is the best way/tool to remove this?
Any advice is much appreciated, I want to learn as much as I can!
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Preston
Mechanicsville VA
Preston
Welcome,
I just put the same carburetor on a stock intake an used the original bracket the only thing I needed was a piece at the end of the throttle cable to attach to the edlebrock, everything else hooked back up. I’m very pleased with the new carburetor can you post a picture of what you are working on.
Mikedbnt
Columbus
Michael
Yes, I will have time this Saturday to take a pic and work on it. Thank you for your help!
jash1990
