New carb starts then dies after 5 seconds
joeybtl
arkansas
Joey
I recently got a new Edelbrock 1406 for my 84 Chevy c 10 and put it in hooked everything up and started it I pumped the gas and it finally started but would stop and die after 2-3 seconds any help?
fast 99
Spokane, Washington
What is the fuel pressure? Is the choke plate closing? Vacuum leak?
joeybtl
arkansas
Joey
Idk the fuel pressure. It’s a electric choke it’s open about a penny wide and I can’t seem to find any vacuum leaks
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
Buy a Holley.
-where's Mike?!
Dmack
Central OR
Dave
Make sure your idle mixture screws are out about 1.5 turns each, not run all the way in.
With the engine off, cycle the throttle linkage a couple times. You should see a constant stream of gas out the accelerator pump nozzles.
If no gas is coming out the squirter, pull the fuel line, put it in a container, and crank the engine to make sure your fuel pump is working.
Can you keep.it running by pumping the gas pedal?
Random thoughts.
joeybtl
arkansas
Joey
I’ll try that when I get home. I can keep the engine running as long as I’m on the pedal yes
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Pumping the pedal???^^^^^^^^^
joeybtl
arkansas
Joey
Yes pumping the pedal or just holding it down
WFO
Texas Panhandle
Have you tried screwing the idle screw in?
joeybtl
arkansas
Joey
Not yet idk how to really like I know but not super good
mo4154
