Neutral safety switch
Cemack
Alberta Canada
K15
Does anyone have a picture of where the neutral safety switch is mounted? I took mine off 2 years ago and cannot remember where it goes. I am just putting my 78 back together now. It is a standard transmission. I don't think the autos would have one
Cemack
Alberta Canada
K15
My '74 is on the clutch pedal linkage.
I'll check it out. See if anything rings a bell. I had it in a bag labeled steering column. I should have labeled everything much better.
Snoots
Roger
Jimmy Sierra
350 w/203
FYI, Automatics have one too.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
@Cemack Here is a picture, best I could find.
Number 9. There will be a switch a lot like it for the brake lights. This diagram is just the clutch parts.
Cemack
Alberta Canada
K15
Thank you. That should help out a bunch. Great exploded view. Putting this interior back together has been a challenge. I've put things together only to find out I needed to do something else first. FYI, the brake and clutch pedal need to be installed before you install the the steering column
Dons79C10
