Need new Vacuum Lines
Inchief
FL
5.3 Vortec
I have been looking through the forums and catalogs and I cannot seem to find new vacuum lines for '87 R10. If LMC has them in their catalog I cannot find it. I am looking for the lines coming off the selector valve and going to the individual vacuum cylinders for heat and AC distribution. Thanks
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Buy it by the foot at Autozone or O' Reilly, Pep Boys, Napa. If no luck there try Brothers, Classic Industries.
  • Like
Reactions: WFO
74 Shortbed
If you're gonna replace all the hose, just buy a spool of it, lot cheaper that way..
Inchief
FL
5.3 Vortec
So the vacuum line harness with the plug behind the selector switch is not being reproduced?
75gmck25
Northern Virginia
Bruce
I've never seen a catalog with the full set of replacement vacuum tubing. Its fairly easy to buy the bulk hard tubing and just replace the lines one at a time. Just pull the rubber ends (where it connects to the vacuum motors) off the old tubing, or use a short section of rubber hose to splice in the new tubing. You could even use rubber tubing for most of the replacement, but its much larger diameter and hard to thread through the confined space under the dash.
Bruce
Inchief
FL
5.3 Vortec
Thanks, for some reason I thought I saw the vacuum line harness in a catalog, I guess not. I will have another look at it and see what I need to replace.
I understand where you're coming from, though. I'd want the color coded stuff and not just black. The colors tell you where they go, which standard vacuum tubing won't do.
smoothandlow84
Steve
Use replacement tubing and wrap labels on each hose to identify...easy
Dons79C10
