Need help!
tteiber
St. Brieux, Saskatchewan
Tanner
K1500
Just installed my rebuilt motor, got it all done and went for the first drive..... But the truck wouldn't move. Shift linkage moves through all gears fine and doesn't make any noises, just doesn't go!!! Could it just be that the torque converter is done for? Or could I have missed something somehow? It drove fine before the rebuild.
Need a bit more info, but did you check your fluid level? Vacuum line, Torq converter bolts, transmission lines to the cooler? Is it 4x4? Do you have the transfer case in neutral? Drive shafts are hooked up? I know the last one sounds funny, but years ago one of my buddies just rebuilt his motor, got it all back together (so he thought). Called me all pissed off, saying his tranny wasn't working correct, "GD truck won't move". So I go over there mess with a few things, slide under the truck and just start laughing at him, and told him "the truck will probably go much faster when you put the drive shaft in it" I still to this day give him **** about it. Just go back though and check all your stuff, make sure it all is hooked back up.
tteiber
Tanner
K1500
fluid levels are good vaccum is hooked up and I think I did it right. Cooler lines are done and ya it is a 4x4. Just gonna pull inspection plate and see if it is spinning the input shaft too transmission
CSFJ
Did the converter seat properly on the input shaft before you bolted it together?
tteiber
Tanner
K1500
Ya I got it going turns out I forgot that the trans cooler and lines were gonna take a bunch of fluid as well. Face palm. My bad topped it up and we are off. This is a th350 trans what makes them shift? The vaccum or inertia inside some how? Seems to not like to shift until at higher rpm
right2bear
Montcalm Co. Michigan
Charles
They shift based on vacuum input. The modulator on it senses the change in vacuum and shifts based on that. I would double check your vacuum lines are free and clear, not kinked off. Where does yours get its vacuum source? I believe off the manifold is the best.
Ya it sounds like your shift modular. I'd check your vacuum line. Yes it should come off of your intake behind the carb.
MikeD
