Need help on a wheel size to choose
87gmc512
Austin
What is the widest 22 inch wheel I can fit in the rear of my 87 short bed without any major mods. Right now its sitting at factory height but i am gonna eventally drop it just a few inches. Maybe a 2-4 drop.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
12 inches is about he max for the rear inner fenderwell clearance. As the wheel travels off camber, anything wider wil rub the inner fenderwell and scuff the sidewall. I had a 12" wide wheel ( not sure of the offset) and it would scuff the inner sidewall terribly. Unless you want to mini tub the rear fenders its will rub.. my square has a 5-7 drop currently with 10" wide x 20 wheels and I have a 3/8" space on the outer fender and about 3/4" on the inner fenderwell. When the rear is off camber, it barely rubs. I have 20x8 up front, but have custom fenderwells.
87gmc512
Austin
So I can run a 22x10 in the rear and a 22×8 or 9 in the front with no problem?
C20NamedWaylon109
