Need help identifying this metal line coming out the back of my carburetor
Truck82
Alderton
Christopher
The title explains this post. What is this metal line coming out the back of my carburetor for? Is it needed or can it be capped off?
This is a mid 70s (I believe 1977) Rochester 2gc carb.
Thanks so much for the help in advance, everyone!
Carb'ed Vortec 350
If you have power brakes, no it can't be capped
Truck82
Alderton
Christopher
This line was tied into the vac line that went to the cruise control when it was a diesel. No more cruise control, so can this be capped?
Carb'ed Vortec 350
Unless you have other items needing a large vacuum port, cap it. I say cap it, when I mean plug it with a brass fitting of the correct size
Normmus
Saskatchewan
Norm
Not needed if your brakes don't have a vacuum boost.
Truck82
Alderton
Christopher
Thanks I’ll get a fitting and cap it off
Truck82
Alderton
Christopher
That’s what I needed to hear. Thank you :D
Just wanted to know, can any vacuum port be capped off? Assuming it isn’t needed on the vehicle.
99 percent of the time. If in doubt post,sometimes they are a vent,not a vacuum line.
3 Ton
Pacific Northwet
Fred
1978-79 78 body, 79 gearing
K-15 Suburban
Also used for tranny vacuum in some instances.
workinman789
