Need fuel filler neck for stepside asap!
xicor37
Crestwood
Tyler
k10 reg cab, short bed, step side
355 TPI
Looking for a passenger side fuel filler neck and hose for a shortbed stepside late style with door to access the cap.
Can't really drive my square without it :(
Thanks,
~Tyler
I need one too, and couldn't turn one up in short order. In the mean time you can rig one up as temporary. I used the original filler hose from a common fleetside, a section of an '89 Celebrity 2.8 lower radiator hose, and a short piece of steel tubing to couple the two hoses together.
Good, detailed temp fix there. :waytogo:
swagger
old house in WV
Steve
350/SM-465/NP-205
Thanks,
~Tyler
I have several, will post pic and you chose.
Do you have any drivers side filler necks in bad need of one for a 76 k10 with 84 step bed :Whoa:
That guy got rid of all his parts and moved out of the states. He had a lot of stuff too.
FWIW, my rigged "temporary" setup is still working great to this day. The fuel has not attacked the radiator hose yet.
nathanjohnson85
