Need Alternator help please
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
This is on my daughters 2014 Silverado. Alternator went out about 3 months ago and also ate the battery in the process. Replaced both and have had no issues until last week. She called and said the Battery Saver Mode came on. Made it back home. Put a meter on the battery and the alternator was not putting out. Took it back to Oriellys where I got it. They tested and said it was good. Put it back on and it was putting out. Now it will work for a short period and then quit. Alternator breaking down under a load? Something else? Looked for bad connections but could not find anything. I just need to get this thing fixed so I can get rids of it and get here something newer. It has 283k on the clock.
Sad Sack
Nebraska
Goober
C15
Is the alternator new or remanufactured you got from O'Reillys?
brooksman9
Olive Branch, MS
Patrick
350 & 305
Reman at $400+ don't want to drop another 400 somewhere just guessing and they aren't going to give me another one.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
It could be thermal - works OK when cool but fails when hot. Thats tough to prove because by the time you take it out and go there, its working again. Can you put a full charge on the battery at the house and then drive the truck there (or is it too far to make it on battery alone) to have them test it in-vehicle? That might convince them to warranty it.
Camar068
Air Force Supporting Member
10 yrs Air Force
just a thought, check wiring under your fuse boxes and such. Also check your ground cables and make sure their good.
Sad Sack
Nebraska
Goober
C15
AS info:
I wouldn't recommend reman but if your daughters truck uses the 150amp style I would take back and say you want the new one for what like $50 more. O'Reillys has a not advertised (I think) "customer dissatisfaction" policy, if you don't like it, get your money back and get a new one instead. I used to work for them and returning an item under that reason is allowed.
AS info:
When I worked at Oreillys if I had to order a alternator in for a customer,I always ordered 2 so did my coworker John,because had so many reman failures.
Sad Sack
Nebraska
Goober
C15
Go green dude!
goldpack
Adirondacks, NY
Donnie
GMC C2500 Camper Spec.
350 with 350 3 speed
Green is what I'm losing!
parts store remans suck....suck the money out of your wallet, ...have a warranty on them,...(like in tommy boy, ...for a box of sh;t) ...they fix them by benching them,...finding what they think is wrong, ...maybe not everything. ...and box it up with a reman tag and out the door it goes....to leave you or someone you care about pissed off on the side of the road.
what to do: buy a new GMC one, (which maybe $400 today on a $700, )
for things hard to buy or just plain pricey: DB Electrical out of Tennessse or Maniac out of Texas makes good new aftermarket alternators. they do not want your junk core to reman,...= so you can recycle it.
(both those use to be american made,...but ...their stuff remains good,...and they sell starter / alternator parts for people to DIY or for professional local rebuilders. ...I know a few garage mechanics and none have gotten a bad thing out of DB in Tennessee. (its a big company with lots of warehouses,...so only 2 days in UPS,... I got one into New York shipped to me from Quincy Mass. )
(both links below say for silverado / sierra)
same price on amazon, (others put a affiliate link on their posts ??..)
brooksman9
Olive Branch, MS
Patrick
350 & 305
I can go for that. If it gets it going long enough until I find her a new truck I'm good with it. Thanks. And it's not another 400
brooksman9
Olive Branch, MS
Patrick
350 & 305
Ordered from Amazon. I won't feel so bad if it's something else and im.only out another 200 dollars
goldpack
Adirondacks, NY
Donnie
what are you looking for,...hopefully nothing with Active Fuel Management / Displacement on Demand
....(I am still getting burned on a 2008 5.3 suburban,...2 dead Lc9 engines like your daughters,...and all I have good is a right head and a left head).....
Sad Sack
Nebraska
Goober
C15
Should have gone brand new....:(
jw23655
