NEED ADVICE for a 350 transmission rebuild kit
Hack Richards
East Kentucky
Richard
K1500
350cc
I have a TH 350 4 x 4 transmission I would like to rebuild and there are so many kits out there I just cannot decide which one to get. I use this truck for heavy pulling and loads to gather my yearly firewood. I also would like to rebuild the NP 208 transfer case while I am at it.
What rebuild kits do you guys recommend?
1982 GMC Frame. 350 engine and TM 350 transmission
Preston
Mechanicsville VA
Preston
Welcome to GMSB from Virginia
I’m not one to advise, but there are many here that will help, good luck on your project
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
4WDKC
Southern Florida
Kacy
Welcome, depending on how heavy the load you might be better off switching to a th400.
Depending on the rear gear ratio in the truck a Th350 is very capable of tolerating pulling some weight. Being a 4x4, it can be pricey to convert to Th400.
Kit all depends on what all you want to done to it and how bad it is. Rusty Nail bought a real nice kit for his and replaced everything, steels, all bushing, thrust washers, clutches, band, seals, vac modulator on and on. What considered a freshen up kit is usually called a banner kit. Comes with clutches, seals, gaskets and sealing rings. Sometimes you can get a kit with just common bushings, thrust washers are usually good, but never say never, Rusty had a bad one cuz whoever built his before did a ****** job and had the end play to tight IMO and it caused **** to eat itself up. Of course his had several major failures in it. A few broken valve body springs, burnt and welded low and reverse clutches, the direct drum and thrust washer ate each other up etc.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Get a quality rebuild kit. No need for fancy racing clutches. Look for a name brand friction (borg Warner, Raybestous, alto) machine the direct piston to fit 5 clutches in place of the factory 4, install 4 bushings innthe sun shell, make sure you drill the lube holes for the extra bushings. Use a wide direct drum bushing, either install a shift kit or internally dual feed the direct clutches. Using a 700 low/reverse roller clutch isn’t a bad idea, the rollers are bigger in the 700 part than the 350. Set up the valve body for a firm shift, use a quality fluid with a good trans cooler, and your good to go. The 350 is pretty durable when they are built right.
Hack Richards
East Kentucky
Richard
K1500
350cc
Thanks Guys! Never realized just how many different grades of rebuild kits there are!
Danger Dave
