MS to prop valve help
roy c
long island
roy
does it matter which way the lines from the master cylinder to the proportioning valve go I 'm customizing my lines and need a little help
There is one line that is 1/4" the other 3/16 thanks roy
firebane
Calgary, AB
Curtis
1/4" lines from MC to prop valve. One fitting is 9/16 and the other is 1/2.
Lines from prop valve to front brakes = 3/16
Line from prop valve to rear soft line = 1/4"
Line from rear "t" to drums = 3/16
roy c
long island
roy
So the front fitting of the ms goes to the rear fitting on the prop valve?
firebane
Calgary, AB
Curtis
Prop valve has its own ports for what goes where.
roy c
long island
roy
What I mean was that there was a 1/4" line from MS to the prop valve and also a 3/16" line also I'm wondering if it matters which way they go on
in terms of the front fitting of the MS or the rear fitting and where on the top
of the prop valve do they go
roy c
long island
roy
thanks for the quick reply. the 1/2-20 does that go on the front fitting of the MS or the rear fitting?
firebane
Calgary, AB
Curtis
Like I said master cylinder has 2 sizes and can only fit one or the other.
roy c
long island
roy
SIR regardless of the size (which by the way the sizes I have do not fit I have to remove the fitting and customize) that's why I'm asking does it matter if the fitting on the front of the MS goes on the front top fitting 1/2-20 of the prop valve. and the rear MS go on the rear prop valve which one is 1/4" line and the other is 3/16" regardless of the fittings thanks
firebane
Calgary, AB
Curtis
The prop valve is designed to equalize pressure going to the front and rear brakes. If you change this you could have unpredictable braking.
So put it the way it was setup.
roy c
long island
roy
there was no way it was all new
Georgeb
Wisconsin
George
K10 Burb Z71
3/16" line to the front and 1/4" line to the rear. Yes it matters. Your master cylinder may have two different size resivoirs with the line from the larger one going to the front and the smaller going to the rear.
roy c
long island
roy
Finally thank you my MC does have 2 reservoirs smaller in the front
which I assumed was for the rear brakes thanks again
The way GM did lines changed over the years, and might have something to do with the weight rating too. Some of mine have the front port to the rear circuit, while others have the front port to the front circuit.
Georgeb
Wisconsin
George
K10 Burb Z71
I noticed that too
imyourhuckberry
