More stuff
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I guess you can’t post more than 5 pics, so here is more valuable stuff!!!
Autometer Phanton nitrous pressure. Includes the sending unit and harness. $100
Autometer Ultra Lite 2 1/16 volt gauge $50
MSD multi step 3 channel ignition controller. $75
MSD shift lite $30
Autometer Ultra lite 2 1/16 pyrometer with thermocoupler and harness $100
The retard box has me curious. How is the timing retard activated and does it require an MSD ignition box or can it be used with stock HEI?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
You need a ignition box. The retard box basically delays the ignition pulses based on what chips are installed. There are 3 trigger wires that retard timing by removing a ground. There is also a trigger wire for the start circuit. Connect that to the starter feed, whenever the engine is cranking it pulls 20 degrees of timing out. It’s great for engines that have locked ignition timing.
here is a link for the instructions
https://www.jegs.com/InstallationInstructions/100/121/121-8970.pdf
BradBow
