Mixing bowl air cleaner transition piece for TBI
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Vortec 383, modified TBI/4L80e
HyperTech makes something for TBI called the Power Charger. Basically eliminates the "choke ring" that goes around the injectors and provides a support for the air cleaner (and also creates a lot of restriction). Got the idea for a home made one on another site - here's what I did.
Bought set of four metal mixing bowls for $11.99 at a discount home goods store called Tuesday Morning. I got the second biggest one and my wife got the other three. The one I used nested perfectly under one of the ring insets of the OEM air cleaner's base. And I cut out the overhang of the base so the transition is smooth and I have the biggest opening possible into the mixing bowl. drilled a hole for the PCV breather tube in the mixing bowl. (Could also use a breather in the valve cover) And I cut the bottom flange off the choke ring, leaving about 1/8" to 1/4" of the ring, and then installed that into the base of the mixing bowl, in the hole that I had cut out. Gave the bowl something to rest on at the TB and also gave it rigidity, it was pretty flimsy with its bottom cut out
78C10BigTen
pennsylvannia
C10 BIG TEN
I have one of those things in my 94 tbi and it never did squat. Think it was called a tornado
4WDKC
Southern Florida
Kacy
Tornado is different, this is to unrestrict airflow into the tb, not create a vortex...Funny thing about this people will call the ghetto for using and actual salad bowl, I had a few do it in a psot I saw so I couldn't help respond with why do you think it has that name and what do you think they used to figure it out? You think they actually paid someone to create this and use it to test before production or would it make more sense to cut up a cheap salad bowl and testing.
Daveo91Burb
Vancouver, WA
Dave
All I know is I spent $12 on a set of four mixing bowls - I took the second biggest and my wife got the other three so I’m out a few bucks and an hour or two of my time. No biggie if it doesn’t do much for me
4WDKC
Southern Florida
Kacy
right, and the bowl you buy designed for this is $40.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I would have to rewatch the engine masters episode on air cleaners, but they proved on the westech dyno that by having a taller more vertical airflow going into the carburetor increases horse power over all other types of air intake systems.
I’m pretty sure the salad bowl even beat no air filter at all. It was definitely at the top of the heap.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Looks familiar. I cut the bottom out of the bowl smaller than needed then opened it up with a disc sander a little bit at a time until the choke ring was a tight press fit. Only difference is I'm a cheap bastard and didn't buy the wife any bowls. One at the 99 cent store and done.
TerColHan
Pasadena, Tx
Rod
Suburban 2500
That Engine Masters episode was great but I think the salad bowl was actually 2nd place. It was just a salad bowl with an open element lid on top. 1st place iirc was a 4 or 5 inch open element air cleaner with an open element lid. Their point was that your engine really wants to pull air down into it so it's significantly less efficient at pulling through an air filter open only on the sides and also that it was better a little vertical height would speed up teh charge which is why velocity stacks worked on race engines (and also why the salad bowl worked so well). Convniced me, I've got these on nearly everything I own that will fit one now.
Jppr26
Deer island
V20 custom deluxe
Dude this is right up my alley, cheap, home build, and a wife pleaser. Definitely going to give thos a shot
bajadiver
