Mango
- Dec 22, 2021
- JacksonWyoming
- Gil
Hay All
Chevy Burb 1989 200,425 miles Running pretty good slight idle skip at stops
Poor fuel mileage not new 11 MPG
So I decided to test the MAP Sensor, Using a Voltmeter and vacuum pump
Connected to Neg battery and middle green wire connected vac to MAP Sensor
Turned ignition on no start volt read 3.8v should be around 5v
Pulled vacuum and voltage dropped like it should?
Engine runs fine
Leave it alone?
Replace it with a Napa one?
Replace it with Delphi
Replace it With AC Delco GM
What ya Think
Engine runs fine
Leave it alone?
What ya Think
